Now that the season ended I went through the process of of replacing everything for my 23k in-ground non-saltwater pool. This is all DIY work. I replaced the old single speed pump with a new Hayward SP3202VSP, replaced the sand filter with a used Hayward swimclear 5030, added flow meter, added zinc anode, converted to saltwater with a Hayward T-Cell-15, and the big purchases what the Hayward Omnilogic controller. with the wireless add-on.
I've re-plumbed and installed all the water components and the pool has been running a couple of weeks with some issues I'm working through as the instructions are a bit vague, I guess if you were a certified Hayward installer you'd have had hands on instruction making it easier. First problem I had was it wouldn't see the pump. A change of dipswitches and a week later for some reason the HUA showed up that didn't initially show it's self so the pump is now being controlled by the Omnilogic. The next issues are un-resolved...
The saltwater generator doesn't seem to be putting out enough chlorine. Even in superchlorinate the output it took 2 days to go from 0ppm to 2ppm
The schedule for the saltwater generator doesn't always work. It turns off for no apparent reason no error code or alarm. Just behaving strangely. I'm hoping it's due to cold water temps and high salt content. I followed the recommended amount to salt the pool for the size at 14 bags and the salt PPM is showing higher than it should at 4600ppm per the T-Cell reading. Not sure if this cell is bad or it is in fact having issues due to high salt and low temps... Theres a flow switch and flow meter and I have the pump speed set to produce a flow going at 52 during the day and 45 over night.
The next issues is the water temp sensor, When I installed it and wired it in. I did see it come up in the controller menu and it's configured as the temp sensor 01 water temp sensor but doesn't show the water temp on the Omnilogic screen nor the remote webinterface. I simply cannot find in the configure to have it display the sensor temp correctly. The air temp sensor works fine and displays in the controller and web interface. I even swapped the air sensor into the 01 interface point to make sure it wasn't a bad sensor.
I think that about covers where I'm stuck at this point. If anyone with experience with the Omnilogic controller install and salt cell experience it would be greatly appreciated... As much as it is working this is the cleanest the water has looked in the year and a half since I bought my house and inherited this pool so I'm moving in the right direction with these replacement components but I just don't have the budget to do all this and hire a pool contractor to do all the installation. If I had gone that route it would have taken me a couple seasons to have accomplished this much in one go at it..
Thanks
Thanks
