Hi all,
I am doing my first clean and gasket replacement on my pump and filter. I have been reading that they recommend gluing the Spyder gasket down. Thoughts? What glue do you use?
If its a 2" valve, then the replacement gasket is available and is glued onto the keyway. If it's a 1.5" valve (which yours looks like) then I think its more common to buy the whole diverter with the gasket preglued.
