I have a MaxFlo on my solar panels heating system. For different reasons, the solar system uses a separate plumbing system than the main one, handled by a different pump.
The pump is activated automatically by the solar control system, whenever it makes sense based on air/water temperature. However I have a Test switch to run the pump bypassing the control system.
The problem is whenever I try running the pump, I hear rattling noises coming from it for a few seconds, and then no other noise but there is no flow.
The pump is a MaxFlo SP2800X5, and I am not sure what to do now. The serial number decodes as a 2007 product, so it might be end of life?
The motor is a Century, with specs: HP=1/2; SF=1.60; PH=1; RPM=3450.
Is it worth to try a repair?
If not, what would you replace it with? I found a used WhisperFlo WFE-6 but it is rated at a much higher 1.5 HP, and it is self-priming, so I am not sure it could work for solar.
Suggestions are appreciated. Thanks in advance!
