Hayward Heater
Most white gasketing material used in furnaces, boilers and heaters are fiberglass/silica based. Newer ceramic fiber fiber based insulation/gasketing material with a higher temperature range should be an acceptable replacement. This is available from Amazon in various "thicknesses" CeraTex 3170 Ceramic Fiber Paper, High Temperature Insulation Gasket or Liner for Kiln Stove Furnace Glass Fusing, Thickness 1/4" Size 11" x 12" 3 Sheets: Amazon.com: Industrial & Scientific . Should be able to cut and tack in place with high temp silicone. Haven't used it myself and compression ratio may be different between the two materials.
