I have a Hayward H series 400 k BTU heater, and yesterday it would hot fire up. The heater is about 15 years old and has never really given me any issues except i had the change the temp sensor once. I opened it up and did some brief diagnostics and I may have stumbled on something that may or may not be an issue. When you call for heat it does nothing, the blower makes no attempt to even start as it should before a problem would be coded. The thing i found is that the relay wiring from the Aqua Logic to the heater never shows power. I would assume that when i activate the heater there would be say 24 vac activated through that relay wiring to tell the heater to attempt startup. I am also checking for power at the actual wiring connections on the Aqua Logic board on the panel, so its not a broken wire to the heater. Is my assumption here correct, that there should be some low vac current in this line to start the heater. If so, i guess the million dollar question is what could be causing this issue.
Oh, and yes I have 240 v power at the heater control board ready for action.
I appreciate any help that can be offered.
I have uploaded a pic for clarity, i am checking for vac on both relay 1 and relay 2 with the heater activated.
