Hayward Heater - Omnilogic Wiring
nstarasher
5
Rhode Island
I have a Hayward W3HP21004T HeatPro heater and I am trying to finish connecting it to a Hayward Omnilogic. An electrician started and is now a no show. I’m pretty capable when I have a little guidance, so I’m hoping someone can share some insight. I’ll attach the photos of the current wiring setup in the heater panel and omnilogic. I can tell that the heater is connected to the omnilogic sub panel, but I’m unsure of how to get the omnilogic to control the heater via automation. There is a Honeywell thermostat cable that runs from the heater to the omnilogic, but is not connected on either side. Thanks in advance!
Welcome to TFP.
Connect a 2 wire cable between the PS connector on the lower right of the HP and a Low Voltage Relay (LVR) connector on the left of the Omni board. Then tell the Omni Configuration there is a heater connected to that LVR.
BTW, you also need air and water temperature sensors connected to your Omni board.
I also want to note for anyone considering a Hayward Heat Pump how stupid their website and support is.
The web page for the W3HP21004T HP does not have the correct manuals.
It looks like you need what ajw22 mentioned. If those are not hooked up chances are you need the Omni programmed as well. Without those sensors not much can run, maybe the pump. Is the Omni on and working?
Thanks for the feedback and yes I have the air and water temp sensors ordered. I also have a single speed Hayward 700 super pump SP2670007X10. It’s currently powered by a plug and outlet. I don’t know if this is something the electrician did or if this standard, but I’m not sure how to wire it to the omnilogic. I’ll post some pictures.
The Omni should have come with a set of 3 temp sensors and all the phoenix contacts. You will have to get the manual to wire and set up the Omni. It’s all low voltage unless the electrician didn’t finish running breaker power to high voltage relays. The only thing that needs high voltage relays are blowers and lights.
The Hayward 700 super pump SP2670007X10 needs to be rewired and powered by a 240V GFCI CB in the Omni panel and run through a high voltage relay so the Omni can turn the pump on and off.
It looks like the upper left 20A CB has nothing connected to it but it is not GFCI.
What is connected to the lower left 40A CB?
A heat pump?
I’ve seen electricians use GCFI outlets and regular breakers maybe that’s how the pump is?
It sounds like right now the pump is wired to an outlet outside of the Omni panel.
The pump needs to be rewired within the Omni panel if it is to be controlled.
