We have a Hayward H200FDN pool heater that worked perfectly before closing last Fall. Now we can not get it to start heating. We have:
Made sure gas is on
Cleaned all firing orifaces/manifold
Tested the igniter
Tested voltage to the gas valve
The fan comes on, then the inductor, then the igniter, but everything stops at the gas valve. My first question is this, our voltmeter reads 23.8 volts, so it doesn’t quite get up to 24V. Is that enough to make a difference?
If not, then is there a way to test the valve solenoid, or do we just replace the valve?
Made sure gas is on
Tested the igniter
