Hello,
I'm wondering if anyone has a 500,000 BTU natural gas pool heater and how does your gas plumbing work?
My PB recommended to max out the BTUs on the gas heater to get things heated quicker, and we've ordered the 500,000 BTU model. The downside of this is of course the gas supply. Currently, I have a standard pressure (1/4 lb or 7 in w.c.) 1" gas line to the equipment pad, but the gas line is 150 ft, so according to the manual and gas line sizing tables, this is way undersized. The PB's response was a not very reassuring - "we'll connect it, see if it works, if it doesn't, you can dig up the gas pipe and replace it with a bigger one".
Now, I don't really want to dig up my backyard, nor do I want the extra expense of laying 150 ft of a huge 2" gas pipe. I've inquired with the gas company, and they can upgrade the pressure in my line to 2 lb. This will however require the use of gas pressure regulators for all appliances to get the pressure down to something usable. Currently, I only have 2 external tankless gas heaters, each at 180,000 BTUs. So I suppose each one can get the Maxitrol 325-BL-3/4 regulator: https://www.supplyhouse.com/Maxitrol-325-5BL-3-4-3-4-Line-Regulator-600000-BTU. The capacity is a bit too much, but this is the only one that matches the piping size that goes to the heaters.
For the 500,000 BTU pool heater, I'm now not sure which regulator should be used. The gas inlet piping to the heater is 1", so I suppose it's better to use a 1" regulator - the same model as above but at 1" https://www.supplyhouse.com/Maxitrol-325-5BL-1-1-Line-Regulator-600000-BTU, seems like a good bet. However, in the specifications it's saying that the maximum single appliance capacity is only 425,000 BTU, although for multiple appliances it's 600,000 BTU. So I'm wondering, if it would still be OK with a 500,000 BTU appliance? The pressure drop across the regulator would be a bit greater, but maybe should still be sufficient. The next size up is the 325-7 model, which handles 1,250,000 BTUs, but has a 1 1/4" pipe, so I think that would be oversized and incompatible with gas line and appliance sizing. The pipe would need to be stepped up and then stepped down, which may not be a good idea. Moreover, this model is much heavier, and more expensive.
So I'm wondering how are people are handling this discrepancy between regulator sizes and heater capacities? I wish I could consult with a "pro" locally, but so far all the plumbers that I've talked to are totally clueless about all this. They can certainly install what I'll ask them to, but it seems I need to design the system myself.
I'd appreciate any advice. Thank you.
