I have a Hayward h250 ed2 propane heater with electronic ignition. It's fairly old, my guess is about 15 years. It's in decent condition however and I keep it clean.
I'm having a frustrating problem with ignition failures. Frequently, when starting it, it will ignite successfully, run for 5 seconds, then will shut off. After it does that 3 times, the "IF" code is displayed on the control panel. Occasionally, it will work fine and stay running after the first ignition (usually when testing it during the day). Problem seems to occur pretty much every time I'm ready to use it, frequently at night.
I've noticed this to be a fairly common problem and I've done quite a bit of troubleshooting based on info from the manual and posts online. Here's what I've already done.
- replaced the ignitor
- tested all the safety switches with multimeter (even though I believe if one of them were triggered or faulty I wouldn't even be able to start it)
- removed and cleaned the burner tubes
- cleaned the orifices
- when it does stay running, I've put a mirror on the bottom and verified all flames are uniform across all burners.
So I'm quite sure the gas is flowing and igniting correctly, but theory is something is causing it to not detect a flame. At this point, I'm starting to suspect the control module itself mostly because I don't think there's anything else to check and given the intermittent-ness of it.
I thought I'd check here to see if anyone has ideas about other causes of this issue, or for some confirmation that it could be the control module before I drop $300 on a new one.
Thanks in advance!
Greg
Thanks in advance!
Greg
