Hayward H150 Error IF - Help!
Laziebun
45
Chicago, IL
Getting an error IF on my Hayward h150.
It trying to kick on three times then throws a error 150, I can hear the fan kick on. The gas line is turned on…I have the igniter out, how can I confirm it’s the igniter? I did not see any flames through the sight glass.
I don’t know if this helps solve the problem. But I did notice the gas regulator was set to off. But it was like that last year and the heater worked fine. Could that have anything to do with it?
If you are talking about the main valve on the left of the cabinet, it MUST be in the on position for the heater to light. If it did work while in the off position, get a new valve.
