My GVA-24 has stopped working in "auto" mode. The green Heating light is on, but the valve is in bypass mode. The temp difference between roof and pool water is more than 10 degrees. If I flip the toggle switch from ON1 to ON2, the valve rotates normally. If I turn power off, set the valve to bypass and then power up, it does not rotate to heating mode. How can I troubleshoot this problem?
