I am having issues with my Hayward Aquarite system again. This spring at startup it would not generate. I tried the power limiter replacement, was not the issue so I ended up replacing the board. It has been running well since then. Now over the weekend we had a large rain (3") and when I checked the next day I noticed the low salt light was on and it was reading a low salt level (1600). I thought it would be odd that just 3" of rain would dilute it that much so I tested the water and it is around 3200 still.
I had rinsed the cell out, did not see much on it, but figured I would clean it just in case as the system was installed by the previous owner and I do not know when they last did it, or how old the cell is. Cleaned it last night with a 4:1 water:muratic acid mixture. Put it back to together and started it up and now it reads 0 for salt level, and will generate for a few minutes and then kicks over to "low salt" and "Check cell". I tried doing the "re-calibrate" on the unit and it does nothing. I never get the countdown.
Does it sound like the cell has gone bad? Again I inherited the system so I do not know how old the cell is, but I have owned it for 2 years.
Ryan
Ryan
