Hayward 8" drain cover screw diameter -making flat drain covers...
Alset2
112
Cent Fl
So I have really grown tired of my Dolphin Sigma getting stuck on the main drains. I have looked and looked but can only find one possible solution . That solution is a 3d printed cover. But with all the filaments ...ugh... and my ignorance about them...Im thinking of trying something else .
I have access to water jet table and I am thinking of just making them out of 3/8" thick aluminum or stainless steel . Id prefer the aluminum so I can powder coat it to look better but then I need to deal with galvanic corrosion, so to help with that I want to order some washers to help mitigate that issue.
So all of that to say , does anyone know the diameter of the mounting screws so I can order the correct washers?
It just such a pain to work under water, I was hoping some one would know so I can only take them out once .
thank you
Neil
In general flat 8" drain covers are not VGBA complaint. Unless you have two drain inlets connected in a T spaced apart. A raised drain cover is designed so that someone cannot block the entire drain suction and get trapped.
Thank you for the link . I have not read much about it yet.
Yes, wife and I have discussed and we do have the 2 drain system spaced 6ft apart (I think 6ft..) . Another factor is we our pool is really secure and very few children in our "older" neighborhood...lol
We both feel ok with it . I just cant stand the robot getting stuck anymore. The hours of my life I will never get back trying to find a solution is scary!
Anyway, thanks again for the link , hopefully some one will come accros this that knows , Im guessing they are like a #8 or so. We will see.
Thanks
Neil
