Hello! I purchased a house recently with an old spa that needs a little TLC. My biggest issue right now is there is a cracked ball valve that I need to replace, but can't find the part. The part is a Hayward 722-UA valve. It is threaded on both ends. I can find replacement 722 valves online, but none are threaded on both ends. I think maybe this is called a "union" connection? I'd like to find a solution that I can just screw on w/o having to cut pipe, cement new fittings, etc.
Here is a picture:
Duct tape was temporary fix to minimize the leak until I finished draining the tub.
Question 1:
What is the difference between the 722 and 723 valve? Are the threads compatible? I found a 723 (link below) that looks similar, but don't know if it will work:
https://www.amazon.com/gp/product/B00CG4EWLQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Question 2:
Looks like there is a newer version out there - do you think this valve is plug-and-play with the old fittings/nuts?
https://www.amazon.com/Hayward-QTA1...rd_wg=bD2wm&psc=1&refRID=ESCKRJWWPXA09616HJDG
Thank you in advance!
Here is a picture:
Question 1:
Question 2:
