New to running a pool as of this year, opened it early due to old owners tarp falling off and there was so much garbage in it, I have shocked regularly chlorine fac is good total chlorine is good, water is starting to clear not cloudy anymore but not crystal, I however cannot for the life of me bring the ph down and alkalinity up, using hth test strips that tests fac tci alk ph th cya, the old owners had a stack of chemicals in the garage I was getting a ph of 8.4 to 9.0 and alk was at a good level, I started adding the ph reducer they had and ph stays the same but alk dropped significantly to about 40 I have a bucket of alk plus but it's going to increase my ph so question is how do I go about balancing them? Do I just focus on getting ph down to proper levels then start adding the Alka plus? But won't that in turn increase my p.h to unhealthy levels? Seems like a vicous battle that I'm losing any tips would be appreciated
