Hi,
We have a 7,000 salt water pool in Central Florida. I've taken over the chemistry myself. Using the Chlorox Test Strips, it tells me the hardness is maxed out on their scale, ~1000ppm. The TFT Test Kit gives me a Calciuim Hardness reading of 300ppm. I know our local water is fairly hard (115 ppm as calcium carbonate), but this time of year, it's often refilled with rain water. Total alkalinity was also very high, 220ppm, if that matters.
I can see hardness deposits on the walls. My question is - Do I have a problem? Total Hardness is "high" but my Calcium Hardness is at the higher end of acceptable range? If there's a problem, what can I do? Thanks!
