Can someone please explain how they have successfully used a skimmer sock? My experience so far has not been great, there have been many cases of air bubbles coming back into the skimmer and upturning the sock & contents.
I thought I knew how a pump worked, clearly not. Any help is appreciated!
Thanks... Jake
- Can they be used during vacuuming, specifically with an automated vac? I tried and it worked great on debris but once I removed the hose from the vacuum plate an air bubble upturned the sock.
- In the morning on regular filter, I noticed that the sock was upturned in the basket. Could this have occurred overnight when my variable speed pump changed RPMs? Would this have caused air to the skimmer?
- Any time the pump is turned off, air goes back to the skimmer and upturns the sock. Is this normal?
Thanks... Jake
