I’ve been doing a lot of reading in old threads and articles which have pretty much indicated I shouldn’t be using my trichlor tabs in my automatic feeder.
I‘m reaching out for some thoughts here.
Ive just completed my slam and am letting my FC drift down to 4 (cya is 30).
I work 3 12s occasionally 1 24 Hour shift. When my days are stacked my pool is already off for the evening by the time I get home and my solar cover remains on unless I’m home and using it (pool is unholy cold - hence the two panels and a cover) So testing and adding liquid chlorine on those days just isn’t feasible as the pump isn’t running and my cover is on.
Someone has recommended using my chlorinator on the days I work and turn it off when I’m home and able to treat with liquid chlorine.
So a few questions on that matter
1. My chlorinator is directly in line (pump - filter - solar panels - chlorinator - return). So if I shut it off, I’m not sure how that affects overall pool flow. Or should I leave it “on” and just remove tabs?
2. Should I be setting my chlorinator to 2 or 4 when I can’t treat with liquid ? Pool math says my target is 4, but is that the number I’m using liquid chlorine for?
3. Everyday I’m home I should test and add liquid chlorine to my target of 4? Is this once a day? I’m assuming everyone using the tfp method is testing and treating once a day to their target?
4. Is it safe for me to add liquid chlorine with my solar cover down?
5. If im reading old threads correctly one 8 oz trichlor tab will raise my cya 2.2 ppm for roughly my size pool?
6. Are you just to maintain your target everyday or is there like a weekly “shock” type procedure recommended as well, not a slam, but just an extra jolt of chlorine.
Obviously im gonna have to watch my cya if I go this route, vac to waste whenever possible. Just not sure how else to do it when I’m leaving at 5 am and not getting home until 8pm several days in a row.
Thanks
Sorry for the question bombing
finally grasping what I’ve been doing wrong for so many years
if if I ever get my inground def going swg:fish:
Thanks
