Handheld brush?
amygtx
23
0
DFW, Texas
#1
I'm trying to clean the walls of my pool as green algae is starting to form, especially around the big light in the deep end. However, I'm having a hard time actually cleaning it. I'm not sure if I'm not getting enough leverage or what, but when I brush, the algae doesn't really seem to be coming off very well. So I thought I'd get a handheld brush and then just get in the pool and scrub it. Is this a good idea? If so, any particular type of brush to get or not get?
jblizzle
41,193
4
#2
I assume since you have algae you are following the slam process correct? What kind of brush do you have? The Wall Whale makes it much easier to brush the sides of the pool.
funandsun
764
0
Bloomington Indiana
#3
Yikes, won't find me in my swamp until its blue cloudy and even then.. lol Let the Chlorine work and do the best you can in my opinion. You could post a pic and that may give us a better sense of what you are considering to jump into
amygtx
23
0
DFW, Texas
#4
I haven't moved into the house yet so I am not slamming yet as I am not there to perform it properly. I don't have the wall whale, just a pretty normal pool wall brush. Well, I have two different basic wall brushes, and neither does a good job. I think I am the problem (not brushing properly?) that's why I was thinking about getting a handheld brush.
The pool is still clear. Just the traces of algae starting to form around the pool light. I'm trying to keep it from spreading.
amygtx
23
0
DFW, Texas
#6
Yes, I am adding chlorine 2-3x per week. I've had the house for a couple of months now. I just need to figure out a better way to brush my walls.
jblizzle
41,193
4
#9
I don't know how you can say it performs the same as any other brush. With the Wall Whale all you have to do is push the brush straight down and the tail forces the bristles against the wall of the pool. Where as with a regular brush you have to also pull on the pole in order to get any kind of scrubbing force on the wall.
Exactly what problem are you having?
amygtx
23
0
DFW, Texas
#10
Yes, the wall whale does a better job of staying against the wall and is easier to move, but it isn't doing a better job of removing the algae, is what I meant. Apologies for not being clear on that.
As for my problem, there is algae growing near my pool light. The algae isn't coming off very well - always seems to be a little left after I brush - when I try to use any brush on a long handle, so I was asking about recommendations for a handheld brush since maybe I could get better leverage that way?
A neighbor said I needed a metal brush. Is that a better idea?
jblizzle
41,193
4
#11
Are you following the slam process? Because if you are not maintaining adequate chlorine levels no amount of brushing is going to eliminate algae.
amygtx
23
0
DFW, Texas
#12
You said the same thing when I first made this post 1.5 weeks ago :) I still have not moved in so I still haven't started my slam yet. I know the algae will come back, that isn't my problem. I'm trying to keep it from getting worse. As of now, the water is still clear and there's just the algae around the light.
If I take the big brush that goes on the pole and hold that big brush in my hand, all of the algae comes off just fine. But that's really awkward and uncomfortable so my thought was to ask if anyone has a suggestion for a handheld brush. I tried the wall whale and it didn't clean the algae any better that the normal brush on the pole, but it's at least easier on my back.
So ... any ideas how to brush my walls clean?
SummerTimeGirl
170
0
Pa
#15
Just got done SLAM myself a few days ago. But I too had been brushing my walls and fixtures with the regular brush but was having issues getting the light clean enough. Then someone suggested I use a toothbrush. So I laid down on my stomach and scrubbed all in and around my return jets, skimmer basket fixture and our light which did have some yucky algae around the rim. Maybe you could try that? It worked great for me. Now that it's clean and clear, as soon as it's warmer I'm gonna jump in and scrub it all again from the inside! Plan on doing that (with a toothbrush for those items) a time or two every week now as well.
PoolGate
2,426
0
Damascus, MD
#16
Why can't you put more chlorine in? Instead of 1 or 2 gallons, put 3 or 4 at a time (or 5 or 6 or whatever it takes). Have you done a full testing battery yet? If CYA is low enough, I would also put a bunch of pucks in the water to keep chlorine up. All you are doing by brushing is moving the algae to the water and filter.
