In-ground plaster pool. Appx 28000 gal. Halfway between deep and shallow end is a bench seat, about 10’ long and 18” below full mark. I have a vertical crack from the corner of that bench seat down to the bottom of the pool, approximately 7’ long. It is a HAIR-LINE crack that does not extend up into the tile line. The “bucket-leak” test shows no water loss to leaks. Plaster is 9 years old but still looks great. No evidence of cracks in the decking and no separation in any seams. When I say hair-line, I mean if I drew a fine point pen line next to it I believe the pen line would be wider. I should also mention it goes down about 3’, then stops for about 18”, then down another 3’ or so. (Looking down through water so may be different when drained.
So, what do you all think? Surface crack in the plaster? Does this happen? Or, a structural failure and needs to be torn apart and fixed? TIA.
