Hack My Pool
Dumb question incoming - I took my sock of CYA out of the pool on Monday evening. It had fully dissolved. Did I read somewhere I cannot backwash/rinse for a full week after doing that (or was that if I used the liquid version)?
My PSI on the sand filter is nearly 2x what it's base line is...
FC 6
PH 7.8
CYA 50
TA is showing 170 as of a couple days ago - do I need to worry about this one? Is this driven down by getting the PH to 7.2 and letting it rise, and bring back down? I think we talked about this one...
Okay - it's a nasty gloomy day - going to use it as a fill day. Pull Joey Dirty back out to filter all the nonsense...
I'll run chems again this afternoon - adjust PH down to 7.2, keep FC in check, and if I can get the sun to show its pretty face I'll run a CYA again later...
Reactions: Mdragger88
Joe Dirt is getting a facelift. I sprung a nasty leak. Here’s the plan…
1. Run a tube from sand filter to bottom of Joe 2.0
2. Run a tube from Joe 2.0 to return.
There will be a valve on the return to assist with easier “on and off”’of when Joe needs to be in action.
So far I have his foundation down:
Co-efficient of friction on the lid is less than the water pressure is applying to the lid. Pat'd...
Did you just physics me? I don’t math, let alone physics!! I didn’t ask to go into the deep end!
I’m now on JD3.0…
It’s gonna be named like a Dang Star Wars character before too long R2D2, C-3PO and JD3.0
  • Haha
