Howdy all, thanks for all the help over the years.
I have a Hayward H400 IDL2 that consistently gets an IF error. When it first appeared it was intermittent, after a few cycles it would always lite. After troubleshooting it appeared to be the flame sensor, which I replaced. Problem was the same, it was intermittently lighting other times it would cycle over and over again and get an IF.
After more troubleshooting, I'll replaced the igniter. Still same behavior and it finally got to a point where it wouldn't light at all over the last few weeks. Cycle's three times and I get an IF.
Went to the service manual tore down the manifold, checked all of the offices and they were all clean. When the heater kicks on it's cycles, exhaust fan runs, gas valve clicks on, you can smell gas, you can see the igniter on in the window, but no ignition.
Today in a final attempt when the gas valve opened I literally blew into the ports near the igniter and an ignited and continued to run and heat.
Could I have a draft problem, low gas pressure, I'm out of ideas to try.
Thanks for any suggestions!
