Gunite issues
jkxpooldesign
69
Florida
Hi, we are at day 7 with our new gunite shell and today while watering it I noticed what looks like a rust stain (See pictures). Is this something I should be concerned about??
bdavis466
Platinum Supporter
Aug 4, 2014
5,517
San Clemente, CA
It would be difficult for the rebar to rust that quickly. That's more than likely a stain from the dirt where water is leaching through the shell.
Try cleaning it with some dish soap and a brush and see if it clears up
Reactions: jkxpooldesign
sktn77a
1,749
Chapel Hill, NC
Yes, if that is rust it will come through the plaster coat if left as is. They need to chisel into the gunite, cut out the offending rebar and patch it prior to plastering.
jkxpooldesign
69
Florida
Thank you. I will give that a try and report back.
Cleaned it with soap as recommended and it looks like most of it went away. I also used something abrasive to go at the spot to see what was behind the issue and I do not see any rebar.
Reactions: bdavis466
jkxpooldesign
69
Florida
Another thing I noticed today was a crack in my gunite that is approximately 5” in width (see photo). Thanks again to all the knowledgeable people of TFP.
