There are number of posts with I feel like i am in a unique situation:
My pool (new built DIY) is finished in stucco over concrete (not sure if stucco is substantially different from gunite in composition). Its basically waterproof but ugly and needs to be painted. Painting is the only option; other finishes are cost-prohibitive. Also, it's fully covered - there is no sun/UV light hitting the pool.
Users on this forum have discussed substantial issues with pool paints and don't have high expectations but I will be happy if it lasts 4-5 years. Based on my research, here is what I have and any advise will be appreciated:
Avoid water-based paints.
Epoxy is strong, flexible and waterproof
Gelcoat - polyester based, not as weterproof and more brittle than epoxy but used extensively in fiberglass pools.
I am comfortable working with two-part paints and have done fiberglass work with both epoxy and poly; so, application is not an issue. The cost is also fairly close.
Any suggestions which route to go? Again, this is clean new stucco/concrete/gunite pool fully covered from sun.
thank you.
- The UV is big enemy but my pool is covered with no sun.
- There are few options:
- Super Poxy Shield (fairly good reviews on Amazon - Amazon.com : In The Swim Super Poxy Shield Epoxy-Base Swimming Pool Paint - Dark Blue 1 Gallon : Swimming Pool Paint : Garden & Outdoor)
- Ramuc-EP (not enough reviews Amazon.com : RAMUC EP Hi-Build Epoxy Premium Epoxy Pool Paint (Monument Gray) : Garden & Outdoor)
- TotalBoat TotalProtect (good reviews, not for pools but used on boats. Amazon.com : TotalBoat TotalProtect Epoxy Barrier Coat System : Industrial & Scientific)
- There is no reason they shouldn't stick well to the rough stucco/cement)
- Unfortunately, epoxys cannot be tinted and impossible to find light gray color that I was looking for (only few standard colors).
- Can be obtained in any color. (tinted)
- I was reading that chlorine may damage it but it's used in pools everywhere. Not sure if there is chlorine-proof gelcoat but I couldn't find any special.
- From everything I have read about delamination and bubbling, it's usually caused by substrate (fiberglass or wood breaking down and then osmosis across gel coat), I cannot imagine that being an issue over stucco/concrete - nothing to delaminate and the rough surface should provide excellent bond after proper cleaning.
thank you.
