Sub-Menu Access
To access the programming sub-menu (remote t-stat, solar, heat/cool, calibration, load defaults etc) press and hold the up arrow and down arrow at the same time until the board displays ”remote t-stat”. Use the MODE button to scroll through the options and use the arrows to change settings. If there are issues with the operation of the board, we suggest that you “Load Defaults” to return to factory settings.
Pool Spa Automation (Remote Controls)
Attach the low voltage lines to the heater control board at the terminals marked “Water Temp Sensor” (See diagram FS1 below). Access the submenu by holding the UP Arrow and Down Arrow at the same time until the board reads “Remote Thermostat Disabled”. Press the UP Arrow so that the display reads “Enabled”. If left alone, the board will return to the main menu and your remote system is now in control of your heat pump. We are unable to assist with programming of your remote systems.
