Hi everyone!
I’m currently SLAMing a relatives SWG 15k gallon in ground pool (I’ve turned off the swg to better control pH for this) and have a few questions:
ph:7.3
CYA: 80ppm
Calcium: 360ppm
I’m not familiar with this plaster they have. It feels like very fine grained pebble finish. Not sure if it’s polished stone or regular plaster. I’m leaning toward some pebble finish (~12 years old)
1) do saltwater pools naturally have thicker water/higher surface tension? I see what looks like skin or film when the water is gentle agitated, and in my freshwater pool of yore that always meant high pH and corrected with acid. Not so here. Trying to figure out if this is inherent to swg pools or a sign of biologics.
2) can cahypo damage the plaster? I’m adding it prediluted, but I’m seeing white powder settle to the floor (calcium precipitate I’m assuming and not Undissolved calhypo), and in some places there appear to be bleached spots. But I’ve never known SLAMing to damage pool finish like this, least of all when you predilute. And I did this on my pool that had new pebbletec with beautiful blue dye. So I’m confused what could be happening with these white spots.
3) why would I be having a hard time achieving the 32ppm level? Inf the evening It’ll be 28ppm, and I’ll add what should be 6pom more. Come back in an hour after giving it a chance to dissolve, and the reading DROPPED to 24ppm. In the last few days I’ve successfully recorded over 30ppm only once.
4) at 80 CYA, at what level is my chlorine at risk of uv degradation?
thank you!
ph:7.3
CYA: 80ppm
Calcium: 360ppm
thank you!
