Grunite Spa - Massage Jets
Scott1975
10
Gilbert, AZ
I am looking for some massage jets to replace the garbage that my plaster company installed.
I have a 1 1/2" Flush mount fittings in a 2" pipe.
I found CMP had some. But nobody appears to carry them.
23315-030-000; 23315-240-000; 23315-340-000; 23315-300-000
Any thoughts or alternatives?
Thank you.
Scott
What you posted is an external fitting that replaces the eyeball and is not the jet. Those are call spinners and just modify the jet stream. The jet nozzle is deep within the spa wall and determines the strength of the jet.
If you are trying to make the jets stronger, that is a different solution.
