- Jul 2, 2018
- 650
- Plaster
- Pentair Intellichlor IC-40
How bad for the pool is it if some of this gets in the water?
I need to clean the big retaining on the side of the pool. At most 4oz in a 20,000 gallon pool. No big deal, correct?
Custom Building Products Aqua Mix 1 Qt. Non-Cement Grout Haze Remover 010900-4 - The Home Depot
Aqua Mix 1 Qt. Non-Cement Grout Haze Remover is a safe cleaner that effectively removes single component, premixed, urethane, and light epoxy grout haze. Can be used on all non-cement grout types. Safe
www.homedepot.com
