Green to Almost Clean in 24 hrs.
rcy
358
Burlington, ON, Canada
Burlington, Ontario, Canada. Opened on March 20. First time in 14 openings (15 years of pool ownership) that I had algae. Not sure why this time (Covid? Lol). It was a slimy layer completely covering the floor of the liner until I brushed it and ended up with the green soup you see in the attached picture.
Anyway, 24 hours later, using just chlorine and a cartridge filter, the little green enemy is mostly dead.
Just needs another good brushing to remove the algae that's still clinging (the dark spots in the pictures).
It's a salt pool, but the water is too cold to run the chlorine generator, so I use a floater until the water warms up.
Newdude
6,943
NY
Sweet job RCY !!! I’ve done 2 similar, once from equipment failure and once due to wacky weather. Both times my Honking pump and cartridges cleared it in a day instead of days or weeks.
I have seen way too many posts with a small filter (of all 3 kinds) taking forever to remove all the dead stuffs once the chlorine did it’s thing. I imagine a properly oversized sand/DE filter would behave similar but my big cartridges are 2-0 in my book and I’ll never try anything else.
*edit. Current signature lists the 17 year old equipment that we inherited by moving. It’s showing it’s age and I would not like to take it into battle. Lol. Will be rebuilding sooner or later.
Reactions: rcy
JJ_Tex
2,322
Prosper, TX (DFW)
Pentair Intellichlor IC-40
Awesome job. By the title, I was thinking you were going to be touting some new pool store magic potion.
Reactions: rcy
Adamphotoman
292
Dieppe New Brunswick
I still have ice, so I was surprised at your early opening. I agree with cowboycasey.
Do a slam. No shortcuts. It is easy to clear up a pool and think you got rid of all the Algae, only for it to go cloudy again. I suspect your pool looked clear when you closed it but it must have been borderline. And you have had a very warm spring....
Reactions: rcy
rcy
358
Thanks.
I used to have a sand filter and if I had cloudy water at opening it would sometimes take a week to get really crystal clear.
Cartridge filter is much more efficient. I'll admit, though, with the sand filter, backwashing was much easier than taking the cartridge filter apart and cleaning (in my case) four cartridges.
rcy
358
I usually open April 1st, but it's mild here and looks that way until the end of March.
I have opened before with ice on the water. Lol.
Agreed that despite my clear water at closing, I must have had unseen algae. I didn't think algae could spread like that in cold water, though. It's currently 41 f.
Reactions: Adamphotoman
Adamphotoman
292
I am impressed that you are cleaning it up so fast with 41°F water. Last year I did my first True Slam and the water remained clear. Before that it kept getting slightly cloudy.
Reactions: rcy
rcy
358
Opened first pool yesterday to be crystal clear. The trick is simple, close late and open early.
Totally agree. I close late October or even November, and open late March or very early April.
That's why I'm perplexed about the algae this opening. It's never happened before.
rcy
358
Thanks. Fortunately, shortly after having the pool built in 2007, I found TFP and so managed to avoid Pool Store magic potions almost since year 1..
