- May 3, 2014
- 58,766
- Fiberglass
- Pentair Intellichlor IC-40
Some products claim they 'bind' the metals and can be filtered out. Reality is much different.
From Stains in Your Pool - Trouble Free Pool
Generally, there is no practical way to remove iron or copper from the water short of replacing the water with new water that doesn’t have any iron or copper in it. You can use a sequestrant to prevent metal stains. Sequestrants bind to the metal and prevent them from depositing as stains. Sequestrants slowly break down in the pool, so you will need to continually add more sequestrant on a regular basis to maintain sufficient level to keep the iron or copper sequestered.
Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam’s Metal Magic and Jack’s Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top brand sequestrants. There are also other brands with similar active ingredients, some of which are noticeably less expensive.
