I have clear water, I can see the deep end drains clearly and almost read a newpaper that flew in the other day on the bottom of the deep end, but there is a green hue to the water in the deep end only (picture attached it was windy). Reading a bunch of the threads and I guess I am stuck for some advise.
Opened the pool on 4/8. Took the cover off and was delighted to find a very dark black pool (picture attached). Levels at opening
FC 0
CC 0
PH 7
TA 120
CH 100
CYA 50
Raised FC to 20 with liquid chlorine for SLAM and have been doing so ever since. Brushed 2 times and have run the robotic cleaner probably 24 hours total. New Pleatco PCC80 filters. The robot is only picking up leaves and fine sand - no more sludge. I have used about 13 gallons of LC. As of 4/13 - CC have remained at .5 or below. I've done OCLT 3 times - 2 less than 1 the other was 1.5. Current reading are
FC 14.5
CC .5
PH 7.8
TA 140
CH 75
CYA 45
I have also placed 8 oz of clarifier in hoping it was fine particles. I read it might be due to the high FC levels, might be metals, might still be algae. I was thinking to lower FC to regular levels, balance TA to get that between 60-80, then see where I am at? Thoughts?
FC 0
CC 0
PH 7
TA 120
CH 100
CYA 50
FC 14.5
CC .5
PH 7.8
TA 140
CH 75
CYA 45
