I’m currently taking care of this pool that has a lot of algae problems. I opened the pool on Saturday and on Sunday I started the chemical process. Here is a follow run down of chemicals used on each day.
Sunday- Metal Free treatment
Monday - 3 Pounds of Shock
Tuesday - None
Wednesday - Chlorinator fixed output set to 100% - Shocked Again.
Thursday - 4 Pounds of Shock
Friday - Algecide 40 roughly 24oz
Saturday - 5 Pounds of shock
The pool is beginning to clear up it is still green now just less harsh and I’m able to see the bottom in the shallow end of the pool. I have the chlorintor set to 100% with chlorine tabs in it. The Polaris pressure side vacuum is also running and I backwash the sand filter everyday. I’m just at a halt at the moment because I’m sorta lost. Do I continue to shock it? Or do I add Algecide or Water Clarifier?
Tuesday - None
