Thanks so much! My pool is filling now and probably the clearest its been since we moved in!
After full and circulated for 2 hrs I'll get CYA to 30 ppm (via sock method), then ph to 7.2, then FC to 12 ppm (via SLAM method with liquid chlorine) and then remeasure CYA. Please let me know if I am misunderstanding..
Once I get chemicals balanced, is ok to use chlorine tabs? I have about $200 worth and would prefer to not have thrown that money away. Im open to switching to liquid chlorine or possibly using both until tabs are gone if that means a clear pool.
You’ll want to re test the cya after a day or so. Then you can adjust the fc level accordingly following the chart.
FC/CYA Levels.
You continue to Maintain slam level fc until you pass all 3 end of slam criteria as listed in the
SLAM Process article to be certain you have eradicated algae before returning to maintenance (target
range) fc levels.
This probably won’t take long since you exchanged most of the water but it’s good insurance so you know you’re in the clear going forward.
You can use the tabs occasionally for a little bump in cya here & there or if you need to go away so long as you’re cya level isn’t already too high. Just make sure you monitor & always maintain the correct corresponding fc levels.
In your area you’ll probably need around 50ppm cya in the peak of the summer. Otherwise use liquid chlorine for your daily chlorination.
The tabs will last indefinitely if kept dry.
The blind use of tabs without respecting the fc/cya relationship is what causes issues.
The idea here is to test & know where you stand then give the pool what it needs , nothing more, nothing less.
If you don’t need cya or the acidic effects of the tabs they are the wrong choice for chlorination.
There’s nothing more special/magical about liquid chlorine per say it’s just that it only adds fc & a tiny bit of salt nothing else.
Adequate fc in relation to cya is what prevents algae from growing.
Not considering the extra stuff in solid forms of chlorine is what gets people into to trouble.
- Trichlor & dichlor add cya & acid along with fc. The cya stays until water is exchanged but the fc is consumed daily.
- Cal hypo adds calcium along with fc. The calcium stays until water is exchanged but the fc is consumed daily.
When those are used for daily chlorination the xtra stuff builds to unmanageable levels.
It’s also much easier to control all the parameters separately vs dealing with a bunch of moving targets all the time when you’re using products that do multiple things.
As mentioned earlier, a salt water chlorine generator can dose the pool for you if you grow tired of the jug lugging life.
