Took the winter cover off and the bottom of my pool is green. The water is clear. My pool is a 18 x 48 above ground. I have a Sta-Rite System 2 PLM 100 cartridge filter. The last two years my pool was crystal clear on opening. Had the winter cover come part way off this year so I assume this is the problem. Anyway, I tested the water using the Taylor K6000 kit. The results are:
FC 0
pH 7.0
TA 100
CH 260
CYA 40
I don't know where to start. I am adding water to the pool now so I can run the filter, but don't know what to do next. Do I scrub the bottom and filter? Or do I add chlorine? At a loss so would appreciate any help!
Thanks!
FC 0
pH 7.0
TA 100
CH 260
CYA 40
Thanks!
