visible green algae. just on the bottom. Just switched back to liquid chlorine from pucks 3 days ago. Had to drain some water to get CYA down from all the granular “shock” I added trying to kill the algae. Hit the pool hard with liquid Chlorine while waiting for my test kit. Probably should have waited but didn’t want algae to get worse.
CYA is now 60ish, FC-24, CC-1, alkalinity 120, pH is high at 7.8-8.
I have ph down but didnt get any muriatic yet.
should I leave pH alone for now while I wait for SLAM to kill all the algae? Ad ph down now or later? Or just go buy some acid And don’t use Ph down?
alos I have been rinsing both filters a lot to keep the algae from turning them green, but I have lots. When is the best time to put new ones in. After it passes slam? Thanks!
