Green algae developed in my pool two days ago. I have a manually chlorinated 16,500 gallon pool with a DE filter. I have been committing the mortal sin of using TriChlor tablets for a few months and I knew the potential CYA problems that would arise, but I couldn’t keep up with having to add straight liquid bleach every Night. So Despite having an FC level of 6.0, I have algae so I’m guessing my CYA of 100 is doing me in. (Below are my full numbers for today). Based on my reading on the forum, I know I need to do a partial drain to reduce my CYA level to like 50? However, I have physical problems with doing that on our property, so I started SLAM today without draining first to try to get things under control until I can figure out how to drain. My question is... how do you drain an Inground pool? I live on a corner lot with neighbors on two sides and the pool is surrounded by pea grav landscaping. When I backwash my pool, the output from the hose is so strong that it blows away all my dirt and pea gravel and I can only keep it on waste for about 30 seconds before I’ve trenched my backyard and nearly flooded my neighbor. Because I live in central Austin, I’m not allowed to discharge to the storm drain, and you need a permit to discharge to the sewer drain. Not to mention I have no idea how to get the water to those places from where my equipment is. Thoughts? Do I HAVE to drain?
if I did manage to figure out where to send the water, What percent of my pool would I have to drain and how do you know how much that is? Eyeball it? I’ve heard about the risks of an inground pool Popping up from the ground if the ground water is high - Is that a real possibility? Any chance I can just do SLAM and not drain it?
Today’s numbers:
FC: 6.0
CC: 0
TC: 6.0
CH: 300
TA: 100
CYA: 100
pH: 7.5
Based on the FC/CYA chart, I added 121 ounces of liquid bleach today to target an FC of 12.
Thanks for any and all help!
Casey
Today’s numbers:
FC: 6.0
CC: 0
TC: 6.0
CH: 300
TA: 100
CYA: 100
pH: 7.5
Casey
