Max Pressure (1-50 PSI) - Default: 30 PSI
_____________________________________________________________________________________
To Set Maximum System Pressure:
1. Check that the green power LED is on.
2. Press Menu.
3. Press Select to select “Settings”.
4. Use the Up or Down arrows to scroll to “Min/Max”. Press Select.
5. Use the Up or Down arrows to scroll to “Set Maximum Pressure”.
6. Press Select to change the setting. The cursor will appear in the first number column (ones).
7. Press the Up or Down arrows to edit the maximum flow rate setting from 1 to 50 PSI.
8. Press Save to save. To cancel, press Back to exit edit mode without saving.
9. Press Back to exit.
Set Pressure Limit for Speed Program
While Pressure Limit is active whenever the pump is operating a Flow type of program, the pressure limit is disabled by default when running the pump in a constant speed mode. Enabling this feature will make sure that the drive is monitoring the system pressure when operating in constant speed mode also.
2. Press Menu.
5. Use the Up or Down arrows to scroll to “Press Limit (Speed)”.
6. Press Select to move the cursor over the "Disabled".
7. Press and the Up or Down arrows to change it to "Enabled".
