- Feb 6, 2015
- 7,814
- Plaster
- CircuPool RJ-45 Plus
Test the pH, TA and CH of your fill water and report it here.
Are you on City of Mesa water?
With our extreme heat for the next two months and a high CH fill water, you may not need to raise you CH right now.
When you do the CH test, continue to add drops until the last drop doesn't change the blue end color any further - and then subtract the last drop that didn't change the color.
Do this for both the CH and the TA tests.
Since you aren't using tabs or other forms of solid chlorine, your CYA won't rise. Liquid chlorine doesn't add CYA.
