Hello,
I have a frustrating problem with my Goldline ProLogic PS - 4 for the past few months. When the main power cycles, either with the breaker or during an electrical storm (many here in FL) it won't power back on.
I went through the troubleshooting guide, and it appears that the voltages etc. are OK. I can list my results here if needed.
The behavior is odd. If I turn on the power to the unit all I see is the main display panel blinking all the LED's rapidly. Nothing on the readout. I have been successful with a work around. If I leave the power off overnight and disconnect the remote wired control display (inside the house) then turn the main power back on it will fire up and function normally. Then I can plug the remote wired control panel back into the board and both work normally until the next power outage. I suspect it is something going on with the main board but can't be sure. Relay? Voltage regulator or cap?
I will provide additional info if needed.
Appreciate hearing if anyone else has experienced this weird glitch.
Thanks for any help.
Mark
Mark
