Hey folks, first post here—although I’ve been a long time reader as I got a handle on pool ownership over the past several years. Alas, I’ve stumbled across a problem I can’t find any answers to elsewhere online of here in the forum.
I have a goldline aqualogic system (dated, I know). 8 relays. With wireless remote. Historically the remote has worked just fine.
Recently I replaced the pump with a Hayward VS pump. I rewired the control for the pump to permit control/programming by the aqualogic system via variable hi/low settings. (Yes I know I can hard program it on the pump, but elected not to so as to be able to control high/low from the aqualogic system, mostly for spa and heating etc).
When I wired the pump to the control, everything works splendidly… except: when the pump is running, the wireless remote reads “The base receiver is not responding”. Interestingly, the remote still functions, so if I tap the filter button the filter will toggle between hi/low/off. The cleaner will toggle on/off. Lights, same. Totally functional, except the screen continues to real base receiver not responding—the obvious consequence being that I can’t see data like salt, temp, or intelligibly change heater settings/temp without either turning the filter off (at which point the receiver responds and screen presents data) or without going outside to the main control panel.
For clarity, the main control panel always displays properly.
anyone have any tips?
