I am currently installing my own in ground pool and having a difficult time getting the threaded joint on each return to seal. So, I’m asking if anyone has used pvc cement to glue the threaded joint? This joint will be buried once sealed and hopefully never to be seen again. I used Spears number 75 blue thread sealant, but even the slightest vibration or movement of the pipe creates a pressure leak, which kinda scares me once i start backfilling. Even using the sealant, i still need to cut out the pipe again to seal, since once the pipe is glued to the back of the fitting, there is no way to unscrew it. Since this will never need unscrewed, then why not just glue the threaded fitting? It should seal solid, right?
Thanks for any advice,
