I have two globrites that have failed, out of warranty of course. I read that the 2024 manufactured units are better, so I bought two replacements. One has been an easy replacement, unlocked from the niche, pulled a pull line through conduit from pool side, new one pulled back through and installed, easy.
The second one has fought me to the extreme. First, trying to unlock from the niche, the lens cover twisted off. Finally got that resolved and unlocked the light from the niche. But it won't budge. Pulled the light from poolside to the point where the light housing pulled off/free of the wire. I've tried pulling wire from pool equipment pad, wire won't budge either direction in conduit.
I'm now trying to feed a fish tape through with wire in place, no joy yet. No idea why this one is stuck. Pool build was only 4 years ago, conduit run isn't more than 65 feet with two turns, I'm pretty sure wire isn't glued in place as the original wire wasn't run till well after conduit was placed.
Not sure what tricks to use. I can get a good grip on pool equipment pad side of wire, but not sure how to pull beyond human strength. It hasn't moved it at all.
Any tips?
Any tips?
