- Dec 26, 2019
- 2,000
- Plaster
- Pentair Intellichlor IC-40
I have 4 Pentair globrite lights, 3 in my pool and 1 in the attached spa, all connected to a single power transformer, tied to a single relay in my intellicenter. Apparently the power flickered here the other night, and now the spa light does not energize at the same time as the pool lights, so my light show is off sequence. If the lamps are set to a solid color, they match, but when using a light show the spa lags by a little bit. Has anyone had this happen, and if so, is there a fix for it, short of replacing the lamp? Don't really want to replace the light because it works, just seems to power on a little bit later than the others.
--Jeff
--Jeff
