Glo-brite replacement options?
SBall
0
Jun 27, 2017
255
Nashville, TN
Friends of mine bought a house with a pool, and two of the three glo-brites are dead. Is there any other plug-and-play light that they can use instead of the glo-brites?
I have had great luck with my S.R. Smith Treo lights, but from the glo-brite manual, it looks like there is a niche/socket that makes using other brand lights a bit problematic. They have an Intermatic PX300 transformer.
There are none that will fit into the Globrite receptacle the same as the Globrite does.
Florida Sunseeker makes some lights that will work, they are larger in diameter so depends on where the lights are located. If the lights are controlled by a Pentair automation, the lights will not coincide with the light colors and themes.
