- Apr 21, 2018
- 139
- Vinyl
- CircuPool Universal40
Before you install that I'd make sure it has enough heat capacity to be worthwhile. From the this manufacturers website (below), the 20 tube model produces a maximum of 5000 BTU/hr and the 30 tube 7500 BTU/hr. By comparison, many gas pool heaters produce 100,000 - 400,000 BTU/hr. You would probably have to have several of the units in order to be effective. However, the product on the website that I listed looks completely different that what you have. I bet the manufacturer of your product has some specific recommendations for BTUs needed for your situation.
Solar Pool Heaters - Solar Pool Heating | Northern Lights Solar Solutions
Solar water heating - We offer DIY solar water heating solutions for solar hot water, pools, space heating and industrial heating applications. Visit us to know more!www.solartubs.com
That a solar heater? Who is the manufacturer? It come with any installation instructions?
I think it'll be interesting to see if I can assemble it properly and if it even works, it's supposed to crwtavheat as long as the sun I shining, I'm actually tempted to hook it up now, especially if our state ends up getting shut down, I'll have a project to keep me busy.That looks like fun. Never seen a solar heater like that before.
I'll post some pics and info when I get started, the way I see it, even if it's only 7.5 or 15k btu, that's a lot more than nothing,Just looking at the heat transfer claim of 7500 btu/hr I agree with previous thread that's not enough to do any good for a pool. I get at least 100,000 btu/hr when my panels are at peak performance right now in Florida. My installation has 9.5 panels. That's only for about 4-6 hr/day but is usually enough for 4-6 deg and gets my pool to or very close to comfortable swimming for my wife so I just top off with gas heat for an hour or two (266K Btu heater).
Will be interesting to see if there's something I'm missing. Price is also robust. 4X12 traditional solar panel sells for about $600. My 9.5 panels cost $5000 including installation. Of course that doesn't compare to your free deal.
Please do keep us informed, it's always neat to see something new tried out on TFP.
Chris
Great point and the price was definitely right!.I'll post some pics and info when I get started, the way I see it, even if it's only 7.5 or 15k btu, that's a lot more than nothing,
Interestingly enough, we saw those all over the place in St Lucia. Hot water heater with hot water storage tank. I believe they work by convection and need no pump for operation.That looks like fun. Never seen a solar heater like that before.
We use those for commercial pools. What brand is it? Are you using another for your acid? Do you currently use liquid chlorine?also working on an automated chlorine feeder, using a peristaltic pump, a timer and a 12v power source. I'm more excited about the chlorine feeder than the heater.
I do use liquid chlorine now, the pump I got from Amazon so no brand name lol, it's just a 12v pump wth no timer built in, my only concern is the resistance of the stock tubing to chlorine, I'll see how it goes, I may have to replace it with a more chemically resistant tubing if it degrades too fast,We use those for commercial pools. What brand is it? Are you using another for your acid? Do you currently use liquid chlorine?
Do you have an idea of what type of flexible tubing is chlorine resistant?If it was not made for a pool, you will need new hose. Be sure to weight the intake tube in your jug of chlorine too.
I was just thinking that the tygon may not be flexible enough, I'll check out the Link, thanksIt needs either to be caulk or silicon based so the rollers can pinch it and push liquid. Tygoon wont work, not flexible enough.
some of this might work just make sure its not braided and durometer number is soft, Silicone Tubing Category | Silicone Tubing & Hose | Tygon®, Silcon® & Silbrade® Tubing | U.S. Plastic Corp.
What durometer hardness is soft enough?It needs either to be caulk or silicon based so the rollers can pinch it and push liquid. Tygoon wont work, not flexible enough.
