I recently changed my sand out for glass, and I'm happy with it but ever since when I do a water test, my cya is lower than it should be. Is it possible that it's filtering it out? I'm losing about 20ppm per month, and haven't been backwashing much, not ANYWHERE nearly enough to lose half my cya. I've always operated under the idea that cya doesn't leave the pool unless water leaves the pool. If it's not being filtered out, is there anything else that could make it convert to something else maybe? The loss is confirmed by both my HTH drop test kit and pool store tests.
