About 2 weeks ago I began having problems with my Hot Springs spa and it was not heating up totally. I was out of town, called service, they found the 2 pole 220v 30a GFI breaker had tripped, reset it and all seemed fine. Couple days later it happened again and after a week the breaker will not reset at all. There is a separate breaker for the recirc pump, etc. and that works fine. We are in Michigan and cold weather, so obviously concerned about freeze up, but here is the strange thing. The 220 breaker has been tripped and will not reset for about 4 days, but the water temp has stayed at a consistent 72-75 degrees. It seems obvious to me that the heater is working somewhat to keep the water temp in the 70's when it is around 30 outside. But, how can this happen with the breaker tripped. Shouldn't there be zero volts to the tub heater with the breaker tripped? Talked to service again, they said everything in the tub checks fine and suspect the breaker is bad. Recommended I call an electrician. Now I am not currently concerned about freeze up because, as I said, somehow the water temp is staying around 70. Is it possible that he GFI breaker has gone bad, but leaks enough voltage to the heater to allow it to run and keep that water temp around 70?? I did talk to an electrician, he couldn't come out right away, but seemed to be suspect since he said breakers don't fail that often. I am not at all opposed to getting the electrician out to replace the breaker, but I hate to throw several hundred dollars at this only to find out it is something else. What else could it be? Any help or ideas? The real peculiar part is how can the tub be maintaining a heat of 72-75 for the last 4-5 days with outside temps between 15 and 40 and the heater circuit breaker tripped that whole time?? Lastly, the hot tub and all electrical including the circuit breakers were installed Fall 2001.
Neal
Hot Springs Grandee Hot Tub
Neal
