When I turn on both the pool and spa lights, my GFCI outlet circuit breaks. When I turn on one or the other, all is fine. But as soon as I turn on the one that is off, the circuit breaks. It doesn't matter which order I turn them on. Any ideas?
What amp rating is the GFCI? What type of GFCI is it? What amp rating is the breaker on that circuit? What type of pool & spa lights and wattage?
My guess is you may have a 15 amp GFCI on a 20 amp circuit.
Please Read This BEFORE You Post and put the details of your pool in your signature.
How do you control your pool/spa lights? Automation panel?
If this has worked OK for you in the past, it probably isn't an amperage rating issue.
It may be a breaker getting flaky (failing). Is this GFI a breaker "proper" meaning it looks like the other breakers in the panel? Or is it an outlet GFI like you might find in your bathroom or kitchen? Outlet GFI breakers (through experience) don't seem to be as robust as GFI breakers you would find in a panel as indicated by their price. GFI breakers are about twice as much as outlet GFI's are. Also, it is not uncommon to have other outlets/appliances on that circuit like your safety cover motor, etc. Check to see if the lights are the only thing on that circuit when it is tripping.
Shared neutral?
I would look into this...
