My water looks blue, with a small amount of algae only .
I prefer to not to run the pump as much as our old pool guy told us to run it. He wanted us to run it from morning til night. I just do 5 hours during the day, from 11 AM to 4 PM, and then every evening and I turn it on, then brush the the small amount of algae that there is toward the main drain, and let the pump run for about an hour or two. I'm satisfied with the way it looks.
The reason for my post is, I'm not understanding why my FC test readings are as they are. It's been 2 months since I put any FC in the pool. I have used stabilized tablets only in the past 2 months. Specifically, Clorox Pool & Spa XtraBlue 3" Chlorinating Tablets. The water has looked good during this entire time.
I do have a test kit, but here are readings from the local pool store:
TC 5.0, FC, 5.0, CC 0.0, PH 7.6, TA 100, CH 200, CYA 45, TDS 3,000
My K-2006 TAYLOR TEST KIT is detecting much, much more FC than the store did. FC 18.0, with CC 0.0. I determined PH 7.7, TA 70, and CYA 50.
Can anyone explain to me, why is FC being detected if I'm not putting it in the pool? Why is CC coming up 0.0 if I'm only using stabilized tablets?
Since CYA is at the level it is, I plan on switching to liquid CH this week.
