- Jul 16, 2022
- 30
- Plaster
- Hayward Aqua Rite (T-15)
I canceled my service company a few months ago and have been learning how to do the maintenance myself. Definitely still figuring things out, but it's starting to come into focus! lol
Wanted to check in with the forums and see if I could get some feedback on my recent tests
Free Chlorine - 3.0ppm
pH - 8.0 (maybe a touch over 8 given the color seemed a bit darker than the 8)
Alkalinity - 80 ppm
Calcium - 250
CYA - 75
Salt - 2200 ppm
Temp - 51 / CSI -0.20
FC - Now that the temps have dropped, I've turned off the chlorinator and this is the first time I've seen the FC drop to a point where Pool Math is recommending adding liquid chlorine. Pool Math is recommending adding 62 oz to raise the FC to 5.0ppm. I looked on Amazon and saw BioGuard Chlorinating Liquid in gallon sizes - Is this the correct product?
pH - The pH has consistently been high - A couple of weeks ago, I added dry acid to lower the pH and achieved the 7.6 target - It's now back up to 8.0+. I've read that the pH will regulate itself. Is that correct, or should I continue adding the dry acid to keep it around 7.6?
Alkalinity - 80ppm - this good?
CYA - 75 - good?
Calcium - 250ppm seems on the lower range of recommended, but given the plaster, I've been told this should be fine. Is that correct?
Salt - 2200 - not sure what my salt levels should be. Seems like this is somewhat of a preference? Any thoughts here would be welcomed.
Thanks again for the help with this!
Alkalinity - 80 ppm
Calcium - 250
CYA - 75
Salt - 2200 ppm
CYA - 75 - good?
